Ring could not be created because of low memory or maximum number of ring instances reached
Check the number of ring instances created using 'show erps' command. Delete one or more ring instances. Also use 'show memory' command to see if the system has enough memory to allocate.
Error
Ring %ring% could not be created
| Name | Type |
| ring | String |
